imports a DXF file
I am using Creo Parametric Release 12.4 and Datecode12.4.1.0
Our customer imports a DXF file into Creo. Because this DXF contains many entities/lines, the model becomes laggy when they try to rebuild the sketch after import. The customer's workstation is high-end (32 GB RAM, 16-core CPU, 6 GB GPU), yet the performance is still slow. Could you please advise whether they need to increase hardware specs, or how best to process/clean the DXF file for better performance?
    Dear Mr. Nguyen,
    please open a PTC TS support case and provide data and sequence at https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log to have a deeper look.
    Harald
    Hello Mr. Nguyen,
    witin a PTC support case you will get an answer for your specific data. Please close this thread by accepting this as solution.
    Harald Hiller
