Dale_Rosema
Improper assembling encountered
  • October 14, 2015
  • 13 replies
  • 7183 views
I received this message today when I was trying to edit an exploded view:
What is "improper assembling"? The model had been regenerated without errors.
Thanks, Dale
Best answer by Dale_Rosema
Files were repaired and return. After one glitch (needing to delete a .xas file from before the repair) and re-verifying the instances in the family table, I no longer get the assembling error.
While .xas files played a small part in the fix, the main problem was corruption of the files.
Thanks, Dale
Dale_Rosema
Currently, I am stepping through the assembly as mentioned by Doug Schaefer‌.
SUMMARY Improper Assembling Encountered error message
Thanks, Dale
Interesting, I have no recollection of that message.  Obviously, I was replying to something in the old system.
Interestingly, you've had this problem before too:
Imporper Assembling encountered.
Clearly, we are both doing something wrong.
Did you see this post pointing to out of date instance accelerators?
Dale_Rosema
I have that in my list of things to look through from searching on "improper assembling".
Unfortunately, stepping through the model didn't work. Everything was green and growing on the way down the tree from the very first item, but when I went back to the exploded view, I got the same error message.
18-Opal
October 14, 2015
Hi Dale,
You can also try the following:
Set option regen_failure_handling to resolve_mode to expose regeneration failure at file opening.
Target flawed component constraints and define constraints again.
Amit
Dale_Rosema
Amit Deshpande
But there are no regeneration failures. The "stop light" is green.
18-Opal
October 14, 2015
That's true, interesting.  What happens after you set the config and retrieve the model?
Dale_Rosema
I have submitted the file to PTC for evaluation. During a WebEx, they were something was wrong with the file.
Case 12791042
Thanks, Dale
Dale_Rosema
Dale_Rosema23-Emerald IVAuthorAnswer
Thanks, Dale
