Inheritance model won't work
- May 19, 2016
- 3 replies
- 3497 views
I am trying to create a model with an inheritance as the first feature after the base datums. If I leave it as MERGE, it works fine. If I change it to INHERITANCE, it fails. I've attached the model I am trying to use for the inheritance. I didn't try to vary any of the dimensions or make any other changes. Just simply created the inheritance feature in a fresh empty model. I tried with another part and it worked fine, so I don't think I am doing it wrong. There must be an issue with the model but I don't know what it is.
