Dale_Rosema
Insert a note from file
  • October 16, 2018
  • 2 replies
  • 2107 views
In WF5.0, I used to be able to insert a note from a file.
We recently moved to Creo 4.0 and I cannot find that command. Tried using the "magnifying glass" to search for it, but couldn't.
Best answer by MartinHanak
click Note button and select note location. You will see Format tab
Click Note from File button and select input file.
Dale_Rosema
Thanks Martin!
One of those things you'd spend hours looking for.
