2-Explorer
August 23, 2019
intersection of part surfaces on datum
  • August 23, 2019
  • 5 replies
  • 2543 views
Hi
I have a part having extrude feature. And plane is also there. on plane, I need to have intersect profile but not able to do complete feature creation in part mode. Attached is sample part file on which I am trying.
What I am doing is as below:
Sleect datum
click on intersect
select all surfaces of part
I am not able to complete this feature. Any suggestion what I am missing on this?
Thanks and Regards
Ketan
Best answer by tbraxton
The copy paste is not required. If you select the solid surfaces of the model you can intersect the plane and create the desired curve. See the enclosed part for reference.
tbraxton
Create a quilt by copying the solid surfaces of the extruded solid.  You can do this with the copy paste (ctrl+C->ctrl+V). Then intersect the quilt with the plane. This will give you a stable feature for the intersection that should regenerate if the parents regen without error.
2-Explorer
August 24, 2019
Okay.. I will try this once.... But why directly it's not working without doing copy paste ? It's redundant.... Does intersect feature demand copy paste first ?
Can anyone help me to have updated part with intersect feature ?
tbraxton
tbraxton22-Sapphire IIAnswer
