Is it possible to rotate an surface edge around an axle? If not - is there any workarounds?
  • March 21, 2017
  • 5 replies
  • 3390 views
Is it possible to rotate an surface edge (3D) around an axle?
Is i possible to rotate anything else but a sketch?
Best answer by dgschaefer
There's no direct way to do so, but you can create the geometry with a variable section sweep.  I covered this at MCAD Central a while back, check out this thread.  Sample Creo 2 part in this post, full explanation starting in this one.
StephenW
What kind of output are you trying to get? For simple rotation about an axis, you can use pattern. Copy/paste the edge to get a copy, then use axis pattern.
hnyström1-VisitorAuthor
I'm trying to create a revolved surface from a 3d edge (not 2d sketch).
In Rhino it is not an issue, it just works.
