Is the "open" dialog box the only way to insert a part into an assembly?
If I want to insert another instance of a part (or subassembly) into my assembly, is the only way to do this by using the Assemble button and the "open" dialog box? Is there not an easier/quicker way to insert another instance of a part, such as "copy" or "insert another instance of" or "insert again" etc. via a right-click menu?
For example, another popular CAD program will let you ctrl+drag a part (or subassembly) from the assembly tree into the assembly. This means you don't have to "browse" or search for a part every time you want to insert another instance of it.
I'm using Creo 2.
