avillanueva
23-Emerald II
March 23, 2017
Is there a method for showing PDMLink parameter values as upper case only on drawings?
  • March 23, 2017
  • 5 replies
  • 2491 views
I would like to show the lifecycle state parameter on drawings but the value delivered is not upper case.  Is there a font I can use that would force to upper case regardless?  I did not see an option to force text to be shown as upper case in text style.  I was surprise to not see anything in knowledge base on this.
Best answer by TomU
One possible workaround is to create a single cell repeat region and then use repeat region relations to display the uppercase equivalent.
IF PTC_WM_LIFECYCLE_STATE == "In Work"
    MY_STATE = "IN WORK"
ENDIF
The table cell would then use the syntax:  &rpt.rel.MY_STATE
TomU23-Emerald IVAnswer
ENDIF
avillanueva
23-Emerald II
March 23, 2017
Close but I think that it does not like format of the parameter call out in the filter.  I am doing this on a format so I could see it as a part model drawing or an assembly drawings. I could pull the parameter  from the drawing itself but that's not a repeat region choice.
avillanueva
23-Emerald II
March 23, 2017
Thank you. There was a step I missed: http://support.ptc.com/cs/cs_27/howto/dwt_relt/dwt_relt.htm
I had to first enter in the right parameter THEN do the relation THEN switch the parameters. Works now
