Patriot_1776
Issues using pattern reference "&p#" (i.e. &p2) in drawings
  • July 26, 2019
  • 11 replies
  • 3736 views
I'm on Creo 3 M130
There have been plenty of times in the past where I've used the patterns "dimension" of "&P#" (i.e. &p2) to show how many cuts etc. a feature has on drawings.  It USED to only give the integer (i.e. "8").  It seems with some upgrade of Creo since the old version I was using (Creo Parametric/Pro 5.0), there was a change where now it gives the value "8 EXTRUDES".  Whaaaaat?  This totally FUBARS me on dwgs, and now I simply just have to use non-parametric text.  TOTAL drag.
Is there a fix for this "enhancement" that PTC foisted upon us?
Grazie!
Best answer by KenFarley
I've seen this also, and had to edit the dimension associated with the pattern, removing the "EXTRUDES" stuff in the dimension editing dialog. Quirky behavior.
Patriot_1776
Anyone else NOTICE this change?
Dale_Rosema
Creo 4.0 M060
No "Extrudes" here.
Patriot_1776
'Sup Dale!  Hmmm, you're using "#d57" instead of "&p57".  Using the "&p" gives an integer instead of real number.  BUT, maybe that's better, and then truncating the decimal places.  When looking at my pattern, I only get the "&p" though...
Perhaps that's a change in Creo 4?  Hmmmm....
KenFarley
KenFarley21-Topaz IIAnswer
