Large Numbers Round On Their Own In Parameters
  • October 5, 2017
  • 9 replies
  • 5259 views
When I input a number that is greater than 16 digits, it begins to round. For example, I insert the following:
2222222222222222222222222.00000
and it automatically corrects it to:
2222222222222222184939520.000000
I don't understand why it is doing this. I need these numbers to be exact becuase it is a code that drives parameters based on the numbers 3 and 2.
For instance, if I put 232323223, an interchange will grab the part associated with each individual number. It is not being using for a dimensional value.
 John
Best answer by pmajor
In the end, I used the Extract function.
IF EXTRACT(CODEBASESTRING,1,1)== "3"
D10=30
BRIDGE="BRIDGE2"
ELSE
IF EXTRACT(CODEBASESTRING,1,1) == "2"
D10=20
BRIDGE="BRIDGE1"
ELSE
BRIDGE="NA"
D10=0
ENDIF
ENDIF
IF EXTRACT(CODEBASESTRING,2,1) == "3"
D40=30
BRIDGE2="BRIDGE2"
ELSE
IF EXTRACT(CODEBASESTRING,2,1) == "2"
D40=20
BRIDGE2="BRIDGE1"
ELSE
BRIDGE2="NA"
D40=0
ENDIF
ENDIF
Though I get an "Probable Error" for the digits that do not exist (because the CODEBASESTRING is too short). I would suggest only using this if an empty cell is used for something not existing. For example, I have 75 total pieces. If I only have a code that is STRING_LENGTH(CODEBASESTRING) =  7, then the pieces past 7 are not included in the assembly. You should do the same for the code as well.
Cheers,
   Jonathyn
Can you use a string parameter to drive your interchange instead of a floating number? That would make it cleaner and there would be no rounding. Possibly an integer may be an alterntive.
pmajor1-VisitorAuthor
The code is configured numerically. For instance, 23232223. I take the mod,10 of this number to recieve the last digit. Floor,10 to get the next number. It needs to be a real number. I am assuming from your answer that there isn't a way to achieve this?
20-Turquoise
October 6, 2017
Real numbers will always have this issue:
http://analytics.ncsu.edu/sesug/2008/PO-082.pdf
http://www.lexjansen.com/phuse/2011/pp/PP12.pdf
http://support.sas.com/resources/papers/proceedings11/275-2011.pdf
You could probably use an integer parameter to do what you are trying to do. However it sounds like what you are attempting to do is extract each individual digit. This is what strings are good at. If you can then post the complete code on how you are actually extracting these digits.
20-Turquoise
October 5, 2017
 John
I would suggest using a string parameter for this since it is actually a part number and not a numeric value.
