manage repetition holes with setting
  • June 28, 2016
  • 7 replies
  • 3050 views
Hello everybody,
First, excuse me for my bad level in English, I am a French, and for misspellings.
My problem is: I create a Table Pattern for extrude 50 cylinders.
The name of the Table is for example: 1234.
I want manage this pattern with a parameter, but I don't know how to do that.
Please Help me !!!
Don't hesitate to ask me more information if you need it.
Thank you.
Romain
Best answer by MartinHanak
it is possible to switch pattern tables using Family Table functionality. See attached part created in CR2 M070.
MH
MH
rbour1-VisitorAuthor
Hi MartinHanak,
Thank you, it is very good but I don't know how can I switch pattern tables after launch?
Romain
I do not understand your question "How can I switch pattern tables after launch?".
You can switch table, when you edit pattern feature.
Inside table_pattern.prt there is family table containing column with table name. This way you can set specific table for specific instance.
MH
