mapkey shading vs. shading with edges
  • August 6, 2018
  • 3 replies
  • 2000 views
We have a system wide mapkey to turn the display to shading
es @MAPKEY_NAMEShaded;@MAPKEY_LABELShaded;~ Command `ProCmdEnvMdlDisp`  `Shading`;
where es is for "environment shaded".
What word would I substitute in for "Shading" when I want "Shading with edges" ?
Creo 4.0
Best answer by MartinHanak
mapkey esh @MAPKEY_NAMEShaded;@MAPKEY_LABELShaded;\
mapkey(continued) ~ Activate `main_dlg_cur` `page_View_control_btn` 1;\
mapkey(continued) ~ Command `ProCmdEnvShaded`  1;
mapkey ese @MAPKEY_NAMEShaded with edges;@MAPKEY_LABELShaded with edges;\
mapkey(continued) ~ Command `ProCmdEnvShadedEdges`  1;
Thanks Martin!  Works great.   B
Mahesh_Sharma
22-Sapphire I
August 6, 2018
If you are working with Creo 4.0, you can use CTRL Shortcuts fro the same, e.g. CTRL+1 for Shading with reflections ... and so on.
