Modeling Express into Modeling?
  • May 30, 2012
  • 6 replies
  • 3978 views
Is it possible to save models created in Creo Elements/Direct Modeling Express into Creo Elements/Direct Modeling?
Best answer by hkramer
this is not possible.
See the last section of this document http://www.ptc.com/WCMS/files/129465/en/FAQ_-_Creo_ElementsDirect_Modeling_Express_4.0.pdf
Can Creo Elements/Direct Modeling and Creo Elements/Direct Modeling Express run
on the same machine?
Users running the current release of Creo Elements/Direct Modeling can also run Creo
Elements/Direct Modeling Express on the same machine. This is helpful for users desiring home or
personal use licensing. Note that the PK2 format is not transferable between Creo Elements/Direct
Modeling Express and the professional version.
cheers
horst
hkramer1-VisitorAnswer
cheers
horst
Thanks Horst. But I find it strange that the data sheet for Creo Elements/Direct Modeling Express states
Easy upgrade when you're ready to grow
Companies needing more 3D design power can upgrade to the full, professional version of Creo Elements/Direct Modeling when they outgrow the Express edition.
How can there be an upgrade if the files from Express won't go into the full version?
This information was sent to the corresponding PTC Departement for clarification and corresponding actions to be taken.
