Mold opening simulation with slider in EMX 8.0
  • June 17, 2015
  • 10 replies
  • 6045 views
Can anyone explain how to perform interference check for slider lifter during mold opening or how to perform mold opening simulation with slider movement?? please give me ur suggestion.
Best answer by RussellJ.H.Hsu
The slider set used in the demo is HASCO single Locking. I changed angle pin length to 90 to increase the pull out distance. The assembly file is available with the link below. It was created in Creo 3.0/EMX 9.0.
https://onedrive.live.com/?id=B7F645E1024EF076!373&cid=B7F645E1024EF076&group=0
There is no additional configuration for slider. When performing mold opening simulation, slider sets will be classified into a SLIDER group automatically.
Use proper values for Total Opening and Step Width. Slider will move along the right direction (X) during mold opening.
Video Link : 6166
shaanmech1-VisitorAuthor
Thank you for your reply sir , but the slider sets are not classified into SLIDER GROUP automatically for me please help me ..... mold simo.PNGmold simu.PNG
Did you use the OOTB slider sets? EMX is not able to recognize the slider components if some specific datums are missing. If custom slider sets are required, the easiest way is to duplicate an existing one and modify it to fit your requirements.
Ryan Kelley‌: Can you please move this entry to the group Expert Moldbase Extension - EMX
