3-Newcomer
Jul 18, 2026 3:04 PM UTC
Need help regarding project reopening
 the image is related. whenever i try to open the file it shows this blank screen. I’m new to creo student edition and don’t know much. I was previously an onshape user. i had made backups and made sure to save it a couple of times before closing. The random save i did while sketching is visible for some reason but none of my extrusions are visible.
i scanned all my pc’s recent files to see if i had accidently saved it somewhere else too but its to no luck. The sketch from the above mentioned case is not fully visible too.
der_Wolfgang
Jul 21, 2026 11:33 AM UTC
By the screen shots I see you are NOT talking about Creo Elements/Direct Drafting. But it looks like Creo Parametric to me.
May be you might wanna ask your question in a more matching forum like:  https://community.ptc.com/t5/Creo-and-Creo-Parametric/ct-p/creoparametric
Creo Parametric should not be confused with Creo Elements/Direct Drafting, formerly CoCreate ME10 (2D) and or ME30 (3D) CAD Products.  You posted your question in the section for Creo Elements/Direct Drafting section.. The chance of getting helpful answers is better using an appropriate forum/section
● cad.de + osd.cad.de ● java-forum-stuttgart.de + jugs.de ● notepad-plus-plus.org ●
der_Wolfgang
der_Wolfgang
Aug 24, 2026 10:55 AM UTC
For the records,    the OP opened a new thread in Creo+ and Creo Parametric -> 3D Part & Assembly Design without giving any hint over here.
