Need to adjust tables & notes using Co-ordinates
  • July 22, 2015
  • 5 replies
  • 1829 views
I am currently working on creo2.0 .
Recently while working with drawings I need to adjust tables and notes to a specific position manually is there any other method I can move the tables and notes .
Best answer by TomU
Try "Move Special".  It is available for both tables and notes.
Dale_Rosema
Ryan Kelley
I think this discussion needs to be moved.
Moved to PTC Creo‌.
TomU23-Emerald IVAnswer
If you wanted to automate this you would probably have to develop some custom automation.  Possibly a customized trail file would work, but most likely something with J-Link, VB API, SmartAssembly (3rd party), etc.
