Need to change the COG location of an imported part.
  • October 7, 2015
  • 1114 views
Hi, I need to set the COG of a lot of purchase part in the creo 3.0 models as per the measured COG provided. Can someone please help with the procedure?
Best answer by TomD.inPDX
They are in parameters once computed.  Look at parameters and the lower right hand corner of the UI.  You have the option to see the mass properties parameters.
