Need to press regenerate more than one time
  • May 14, 2019
  • 6 replies
  • 2769 views
I've a few models, parts and assemblies, where I need to press regenerate, more than one time, to complete the regenerate process. can you explain me, why I need to press more  than one time, the regeneration icon?
Best answer by MartinHanak
YES your idea is correct.
one of the reasons may be relations defined in your models.
CAD_user14-AlexandriteAuthor
So it means, that the first regeneration, doesn't update the relations?
How it's the workflow of regeneration? In the other CAD packages, that I've been using till today, i only have the need to do one click on the regeneration icon, for a complete update!
in Creo one regeneration works well only in case that the model is built sequentially. If this condition is not met then more regenerations are needed. To understand regeneration process you have to understand how the model is built. If you want to get help from me, please upload one "problematic" part.
