Note Properties in Creo 3 not the same as Creo?
  • September 19, 2016
  • 6 replies
  • 3508 views
We use Creo at work however at school we have creo 3.  One of the most annoying issues I have is when I make a note, in Creo 3 I type right in paper space.  However in Creo a Note Properties box comes up where I can type my text in there.  Is there a way to get the Note Properties box to come up in Creo 3?
Text box below in creo.
    Best answer by TomU
    This properties box was removed when Creo 3.0 was first released.  Due to customer complaints, it was added back into the Creo 3.0 M100 maintenance release.  If you are running M100 (or later), you can right click on the note and click "properties" to open this dialog.
    TomU23-Emerald IVAnswer
    dholloman1-VisitorAuthor
    Tom,  How do you go about getting the maintenance release?
    If it is the academic version on a school server, the administrator will need to request the new build from PTC.
    I have downloadable edition that is used for school.  Sorry for the confusion.
