Opening a STEP File in CREO
  • June 20, 2016
  • 6429 views
I have converted the Creo Assembly into Step Format.
While the opening the step format again into Creo  , a Menu Manager Tap is opening and then I need to Keep on clicking the Done/Return Option, Which consumes a lot of time.
Is it possible to do th above in single click, or Is there any other way to open the step file directly without any questions in Creo....
James621-VisitorAnswer
