Options tab in surface copy command does not work
Hello everybody,
I am trying to copy a surface and fill in a hole. when I select my surface and select copy and paste it brings me into the surface copy command. there is 3 tabs at the bottom of the ribbon bar, References, Options, and Properties. References and Properties tab open up when I select them but the Options tab does not. The text turns black when I select it but the drop down window does not show up.
Any ideas? I am using Creo 3.0 M030.
Thanks in advance.
