Parameter, relation question
  • October 8, 2014
  • 6 replies
  • 2047 views
In my assembly I have created a parameter, relation and a note calling the parameter which shows the value of the parameter. I placed this note on my graphics area flat to screen. To change my parameter value I have to open the parameter and change the value then select ok.
Is there a way I can just select (double click) the note on the screen and change the parameter value there? I am running Creo Parametric 2.0 M100.
Thanks...
Best answer by Gucio
look at the sample - are you able to change value of the note??
hi,
select note > RMB > Value
regards
gucio
DRFaust12-AmethystAuthor
I can not select the note from the graphics area and when I select the note in the model tree and RMB I do not get the option "Value".
Thanks.
Gucio16-PearlAnswer
