Problem with Units using Pro/Program
  • January 6, 2015
  • 5 replies
  • 1645 views
Hi again
I am using Pro/Program to generate a part, the problem that I have occurs when I ask for angle dimensions in the INPUT section, because I answer giving a dimension in degrees, but Pro/Program takes the answer as radians, destroying everything... When I go to fix the dimension, changing it manually, it has the right unit (degrees).
I don't know what to do to change the angle units in Pro/Program...
I hope you can help me solving this problem.
Thanks for your attention
Best answer by MartinHanak
I met this problem in Creo Parametric 2.0 M020. When you enter value using Pro/Program, then Creo applies radians instead of degrees on this value.
The problem is resolved in Creo Parametric 2.0 M110.
Martin Hanak
Mahesh_Sharma
22-Sapphire I
January 6, 2015
Which version and datecode of Creo you are working with?
Show a copy of the section of Pro/Progam that you think is making this change. By itself Pro/Program does not use radians.
Martin Hanak
That's a nice bug to add to software.
