Productview will not publish
  • April 6, 2011
  • 2226 views
I have an issue with the Productview publisher. Some of my drawings and assemblies are requiring me to select "Check Out" or "Continue"
when opening the files which is causing the publisher to hang. Is there a way to disable the prompting so I can get the files to publish. Not sure
why Pro/Engineer is thinking I am trying to change the files during retrieval process.
Try adding below config option
dm_checkout_on_the_fly Continue
