ProProgram syntax
  • April 13, 2017
  • 3 replies
  • 1969 views
I have defined a condition for a feature creation in ProProgram which works fine:
IF D42 > 0
...blah...feature definition...
ENDIF
But trying to add a second condition yields this error:
IF D42 > 0 AND D48 > D43
!*** ERR: line contains a bad symbol or is otherwise invalid
Same goes for this attempt:
IF D42 > 0 AND IF D48 > D43
I assume this is a syntax error. Can someone please help me out with this?
Best answer by BenLoosli
The conjunction operand is &, not AND.
IF D42 > 0 & D48 > D43
   expressions
ENDIF
You can evaluate any Pro/Program relations in the standard relation editor to see is they work before moving the code to the program.
Check out the WF4 Help Topic Collection Fundamentals.pdf for the symbol syntax for relations.
A colleague suggested nesting the ifs like this (and it works):
IF D42 > 0
IF D48 > D43
ENDIF
ENDIF
Still I wonder if there is a way to do the two conditions in one if nest?
BenLoosli23-Emerald IIIAnswer
   expressions
ENDIF
That works. Thank you.
