Publishing PDFs
We're currently publishing our drawing files as PDFs. One of the problems that was recently pointed out to me is when some symbols appear to shift dramatically during the publishing process.
I've narrowed down what I believe is the culprit. When created a PDF directly from Creo 2 (File > Save a Copy) we are given the Font option of either Use True Type Fonts (default) or Stroke All Fonts. When I leave it on the default, it appears the same as our published PDFs. When I change it to Stroke All Fonts, everything appears as it does when printing directly from Creo.
Is there a way to make the publisher use the Stroke All Fonts option when creating PDFs?
(Even better, is there a way to make this the default regardless of the source of the PDF? Creo and the publisher?)
