question
  • April 16, 2015
  • 5 replies
  • 1901 views
usually when i use sketcher mode, randomly in between many colour lines appear,  and when i zoom in or zoom out they go but appear again after sometime. is there any way to stop this?
Best answer by pjuvekar
Hi Mahesh,
For sure! I resolved this issue by first creating a rectangular sketch which I placed at a particular angle. Then, I extruded it and added a taper to get the desired design, and then cut it. I will put this as the correct answer!
Thanks again!
I do not understand what do you want to get from your pictures. Please upload another pictures.
Martin Hanak
... and upload the model, if it is possible.
pjuvekar1-VisitorAuthor
Hi Martin,
I was able to resolve the issue by applying a taper while extruding. Thanks for your answer, I'm sorry fr not getting back to you earlier as I'm not here often.
Thanks again!
Mahesh_Sharma
22-Sapphire I
May 13, 2015
Hi Purva,
Can share the information about resolving this issue and mark that as correct answer to the post.
pjuvekar1-VisitorAuthorAnswer
Hi Mahesh,
Thanks again!
