References
  • February 25, 2010
  • 3 replies
  • 1821 views
Anyone ever got this message? (I will try to attach a pic to the next post because this stupid forum won't let me at the moment). I am in Edit Definition for an extruded feature with a simple rectangular sketch. 3 sides of the rectangle are Use Edge and the 4th is Offset Edge. The references have been lost because of a change to the parent part. I have the option to Update one reference and Replace the other two. It seems straightforward but I can’t close the References dialogue box even though I have updated or replaced the references. If however I delete them so there are no references then I can close the box. Of course then I have go back to the references box or to the constraints menu to constrain my geometry. This makes “Replace� in the references dialogue box pretty much redundant.
What does this mean? "Could not access ftp directory: '/opt/d00/content/download/docs/forums/thumbs'. Please check your FTP Settings." I'm getting pretty mad at computers right now. And it's only 9.30 a.m.
Who's the moderator for this group?
I will try this with a link, seeing as I can't seem to post directly. Let's start again. Anyone ever got this message? (I will try to attach a pic to the next post because this stupid forum won't let me at the moment). I am in Edit Definition for an extruded feature with a simple rectangular sketch. 3 sides of the rectangle are Use Edge and the 4th is Offset Edge. The references have been lost because of a change to the parent part. I have the option to Update one reference and Replace the other two. It seems straightforward but I can’t close the References dialogue box even though I have updated or replaced the references. If however I delete them so there are no references then I can close the box. Of course then I have go back to the references box or to the constraints menu to constrain my geometry. This makes “Replace� in the references dialogue box pretty much redundant.
