regarding the creo applications and topics related to creo useful for mechanical engineer
  • November 1, 2014
  • 5 replies
  • 2286 views
I'm a graduate in mechanical engineering and I'm just a beginner in creo .I would like to know the applications of creo that would relate to a mechanical engineer.
I recently got to know about advanced framework extension which was useful for me so I would be obliged if anyone can help me with more advanced areas in creo where I can expertise. Help me with advanced topics in creo useful for mechanical graduate
Best answer by TomD.inPDX
Most people working on these projects will utilize the framework extension. Secondarily, the cabling module will also help with wiring your project. If aerodynamics are seriously considered, advanced analysis and surfacing is probably helpful.
This level of effort is typically a team effort as a full development project may require more time than your degree would normally take.
Being a student, you can get a great deal on an academic version of the software and its extensions. Just be aware that compatibility with the full version is limited at best.
Hi Chandrasekhar,
This post might be too open-ended. Creo Parametric has VERY broad spectrum of applications for engineering design. Can you tell us what you are looking to accomplish so the community users can tell you if the software has the functionality?
Im looking forward for creo in designing an automobile. I have very little knowledge about different areas in it PTC. So im looking forward in designing a completly equiped student formula racing car so im enthusiasic to know about the advancements in Creo which would help me in the long run
