renaming problem in creo 3.0
  • April 16, 2015
  • 1243 views
where is the arrow which allows us to select components in a assembly to rename....Capture1.JPG
Best answer by msteis
After you select "ok", another box should appear allowing you to rename each component separately or automatically using *.
msteis1-VisitorAnswer
