REPEAT REGION FILTERS
  • February 10, 2015
  • 6 replies
  • 4903 views
Hi everyone,
is it possible to have a filter in a repeat region like this:
if &asm.mbr.name =*X1* then &asm.mbr.name else &asm.mbr.name&asm.mbr&ptc_wm_revision
so, if name is "390972X1" it shows only "390972X1" otherwise if name is "6512453M" it shows "6512453M1" where 1 is revision
thanks!
Best answer by TomU
Sure. Here are the steps.
1.) Go to "Table", "Repeat Region", "Relations", then select the region in the table.
2.) Expand the "Local Parameters" section of the window.
3.) Create a new parameter to hold the changing value. Let's call it "NAME" (String)
4.) Make sure "ASM_MBR_NAME" "ASM_MBR_PTC_WM_REVISION" are already listed as parameters. If not, add either manually add them (type doesn't matter) or go back out and temporarily add columns with the parameters (this will add them to the parameters list in the relations.)
5.) Add the following relations to the relations section at the top.
IF SEARCH(asm_mbr_name,"X1") > 0
NAME = asm_mbr_name
ELSE
NAME = asm_mbr_name+asm_mbr_ptc_wm_revision
ENDIF
6.) Exit the relations editor.
7.) Change the repeat region parameter in the table cell that currently reads &asm_mbr_name to instead read &rpt.rel.NAME. This may be simpler by right clicking on the cell and choosing "Report Parameter", "rpt..", "rel.", "User Defined", and then type "NAME".
Filters can use "and" (&) and "or" (|), but not "if' or "then". Instead use repeat region relations to dynamically switch, append, or alter values as necessary.
cspinelli14-AlexandriteAuthor
thanks, can you show me a way to do that?
TomU23-Emerald IVAnswer
NAME = asm_mbr_name
ELSE
ENDIF
