Repeat Region Parameters Question
  • October 16, 2013
  • 7 replies
  • 3132 views
Greetings,
Is there a source that lists, or better yet, explains the syntax parameters available for repeat regions?
Phillip,
try PTC Help Center. It is available on separate DVD in Creo 2.0.
Martin Hanak
18-Opal
August 17, 2015
Phillip1‌, did you ever find a list the function syntax  for repeat regions?  Every once in a while I look for this and don't think that I ever found anything comprehensive.  When I search the help for Creo it doesn't come up.
Phillip113-AquamarineAuthor
Lawrence,
I didn't find an actual list. I was able to find what I needed and resolve the problem I had.
18-Opal
August 17, 2015
Bummer but glad to hear you made do...can you share some tips on how you searched for information on a particular function.  For example, I have tried the following and other variants, but cannot get anything: "Repeat Region Relations Exists".
Thanks!
