Replace or change the type at several profiles at once
  • November 3, 2017
  • 2243 views
Hello.
It is posible to replace or change the type at several profiles at once? For example, preselect several profiles and change the type to new one.
Best answer by SamuelBrantner
Hi @YaroslavSin,
that is not possible as modify type can have a huge impact on references in the assembly. The multi-ref support is only valid for the modify size functionality.
greetings Sam
SamuelBrantner
Hi @YaroslavSin,
greetings Sam
Greetings Sam
