RESTRICTED VALUE PARAMETERS
  • January 15, 2018
  • 11 replies
  • 4852 views
hello,
i would like to ask if it possible (with restricted value parameter or something else) to choose for a parameter a value between a restricted value and something added manually.
for example: parameter XYZ could have a value N/A or a numeric value added by the user.
thanks
Best answer by MartinHanak
possible solution no.1:
Create a pair ofr parameters MYPAR_EX and MYPAR_VAL
MYPAR_EX = Yes means that MYPAR_VAL value is defined ... this represents MYPAR_VAL = numeric value
MYPAR_EX = No means that MYPAR_VAL value is not defined ... this represents MYPAR_VAL = N/A option
possible solution no.2:
Set numerical value that will represent N/A option ... for example 9999999999
A restricted parameter can have only one type. It cannot select from both a numeric and a text character string.
You could have a relation that detected that a given parameter was not present and set another parameter accordingly. Use the "exists(parameter_name)" function.
cspinelli14-AlexandriteAuthor
ok, thanks. but it is possible to set a parameter via drop down menu?
thank you very much,
i like solution n°1 but i have a question. if i set this relation:
IF MYPAR_EX==NO
MYPAR_VAL="N/A"
ENDIF
then i will have MYPAR_VAL as N/A. if in the future i will change MYPAR_EX to NO what will happen to MYPAR_VAL?
please explain your situation more precisely. I do not understand how are you going to use your parameter (containing numeric values or N/A string). Do you really need to have numeric parameter ?
