Section tool interferes with unrelated part
  • July 18, 2015
  • 7 replies
  • 3227 views
On Section, I can choose which parts will be chopped and which ones will not. But as the title says, it prevents me from selecting other unmarked objects that would be hidden if were included.
How to stop this ?
Creo 2
Best answer by MartinHanak
Lucas,
I was able to reproduce your problem in Creo 2.0 M070 - see attached assembly. Parts KOLIK and DEKL_DOLNI can be selected in graphics window - place cursor on the part, press RMB and use Pick From List command. Unfortunatelly Creo does not highlite the part in graphics window. The part is marked as selected in Model Tree, only.
I think the only way how to proceed is to contact PTC Support and ask them to judge Creo behaviour. I wish you good luck doing this.
Martin Hanak
Lucas,
can you upload a picture or Creo data ? I think that you know, that when you create planar x-section in an assembly, then every component located in front of a plane is removed from display.
Martin Hanak
lsilva1-VisitorAuthor
A screenshot was attached.
Everything works as supposed
But after applying the tool, I am unable to select any object of those circled in red
I've changed smart filter to geometries, right clicked on the objects, but nothing.
Lucas,
Martin Hanak
