Sections tab not funtioning in Blend tool...
  • January 15, 2019
  • 3 replies
  • 1819 views
Currently one of my co-workers computer does not pop up the sections collector when you click on the sections tab in the blend tool.  It is localized to one user, and I have attempted to re-install the software.  Any ideas on what is wrong?
Best answer by MartinHanak
click File > Options > Windows Settings > Restore Defaults button
-OR-
remove %APPDATA%\PTC directory
-OR-
sbender1-VisitorAuthor
This was pretty much correct!
File -> Options -> Windows Setting -> Reset Panes’ Position
The above solved the problem, thanks for the help.
Mahesh_Sharma
22-Sapphire I
January 16, 2019
@sbender
As Martin mentioned use "Reset Panel position" in File > Options > Windows Settings.
Any movement of panel stores in UI file, hence clearing cache also fixes this.
