Selecting Constraints
Hello
I am and old Solidworks user that has since moved to Creo 3.0. I was wondering if there was an easy way to select and delete constrains in creo similar to the way you delete constraints in solidworks. When I try to click on any particular constraint in creo I am not able to actually select it and delete it so I have been relying on over defining the part then deleting the old constraint
M
