"Set/add drawing" from drawing Shortcut menu.
  • March 9, 2016
  • 4 replies
  • 1993 views
When on a sheet of multiple details in a .drw file, I used to be able to switch between parts by right clicking the view I want, then the shortcut menu would give me the option to "set/add drawing model" to the current view.
I would be able to quickly change the model shown in the model tree to the new model I need.
This seems to have disappeared in Creo3.
Anyway to get it back?
I bet carpenters would just love it if their hammers changed every few years and they were worthless until they learned how to use the new ones.
Best answer by mender
The ability to change the model/rep shown in the model tree by picking a view was not implemented in the change to the behavior of the Model Tree in Creo 3.  This was fixed in Creo 3 M030 as follows:  in the Model Tree, and in the RMB for a drawing view, adding a command Use Model In Tree.
Separately, there was a problem that caused some cases for Set/Add Drawing Model to be missing that command, notably in the RMB on the selection of a part in an assembly view.  This was cleaned up in Creo 3 M040.
StephenW
I still get the SET/ADD DRAWING MODEL in my right click, unless the view is already on the currently active model. Creo 3 M040.
I'm using M020.
Here's a pic of what I'm looking for.
In this pic, the current model is set to the -84 part as shown in the model tree.
I want to set the -42 part to current.
I used to highlight the view of the -42 part and right click. The shortcut menu would then have and option "Set/add Drawing Model" option.
That appears to be missing in my version.
I have looked in the File>Options>Shortcut Menu and the option is listed under Compenent>Primary and it is checked.
But it is not listed under Drawing View>Primary,Object Commands or Properties.
And that where I need it.
Thanks for any help.
mender12-AmethystAnswer
Thanks for the info.
