set datum won't display correctly
  • June 4, 2010
  • 0 replies
  • 471 views
I have datum B attached to the Ø160 dimension. When I add the gtol the datum flips as shown. If I drag the datum below the gtol box the datum base moves to the top of the gtol box. It is determined to cross the gtol box no matter what I do. Aaaargh!!! However, if I redefine the datum and select the Ø200 dimension it looks fine. Do you have any ideas on what is happening and how I can fix before I put my fist through the monitor? 🙂
Eric
Wildfire 4.0 Datecode m090
Windchill 9.0 Datecode m030
