Set flexible dimension in a range
Hi everyone,
I'm facing an issue regarding an expectation from designers of my team.
They would like to set a range for flexible dimension.
For instance, I insert a spring in my assembly. I set it as a flexible component, thus the spring's length changes according the assembly position.
In the case of a lenght higher than the maximum theorical spring lenght, I would get a regeneration error or an error message ....
Does anyone has an idea ?..
