Share Network:
  • July 8, 2014
  • 0 replies
  • 606 views
I am attempting to use Share Network for the first time. I have a half dozen harnesses that I want to run through cable clamps. All of my harnesses were routed without clamping originally, now that the clamps are in placeI want to redefine my path so all harnesses share the same Location points on the clamps.
While the concept of Share Network seems to be working, it appears to be placing each harness side by side instead of in a round grouping that would fill the clamp. Now I have my original harness on the centerline of the clamp, and everything else laid out to one side.
Any advice out there from someone that has used this before?
