Sheet size while adding sheet
  • February 11, 2015
  • 2 replies
  • 1454 views
I was bit annoyed by the default sheet size its always taking while adding new sheets in a drawing. Is there any option where it will ask the sheet size / format to use when i add a new sheet.
Thank you
Regards
Basil Paulose
Best answer by ClintWalton
Basil,
The default sheet size when adding a new sheet to a drawing should be the size of the format that was used at creation of the drawing. If there is a typical size sheet that you use, I'd recommend using a default drawing template/format of that size.
As for an option of prompting the user for a size, this does not exist. Martin's mapkey idea might get you there.
Basil,
I think the only way how to get what your need is to create mapkey.
Martin Hanak
Basil,
