sheetmetal
  • June 6, 2015
  • 5 replies
  • 2421 views
How can i insert isometric drawing and flat pattern of a sheetmetal in the same drawing sheet?
Best answer by bduncan
11.gifOff course!1QQ图片20150606220253.png2.QQ图片20150606220433.png3.drawing moldes>add moldes>QWE_FLAT1
bduncan17-PeridotAnswer
Can I have some additional help regarding this, please?
I've done the family table, everything looks fine and dandy whilst in the drawing. However, if I want to print it(seen only in preview, or on the paper of course), or export it to .dwg or .dxf the view that was flat patterned turns back into its bent shape.
Dale_Rosema
Make sure you have both instances of the model in your drawing if you need them.
One flat pattern and one non flat pattern.
That way you can show both on the drawing.
Mahesh_Sharma
22-Sapphire I
June 13, 2015
Elango,
Does the information in last reply answer your question? Please mark the reply as correct answer, if this answer your question.
