Shortcut Codes in Drawing Notes
  • October 19, 2015
  • 6 replies
  • 9901 views
Hello All,
I am trying to work out the shortcut codes for use in drawings.
I know a few eg:
Diameter Ø. Alt 0216
Degree ° Alt 248
Theoretical Exact Dimension Boxes, with xyz inside box. @[xyz@]
I am specifically after the GD&T symbols, so if anyone has those it would be good.
If anyone has a full list that would be amazing!
Best answer by RonSt.Pierre
check out this thread
Re: Stuck typing symbols in drawing
It should answer all your questions
ron
KenFarley
Most of what you need (except the box around text one, "@[ text @]") is available in the "Text Symbol" menu. I don't know if most of the GT&T symbols are available via the "ALT" ASCII table lookup. One other trick I've somehow retained in my head is a superscript/subscript one:
"X@+2@#" gives X squared
"X@-2@#" gives X sub 2
But, I don't really use those anymore because it botches up the line spacing. If I need superscripts, I use a word processing program like MS Word to get the symbols I need, then copy them into the Creo note text.
gnewman1-VisitorAuthor
Hi Kenneth, it wont let me use the symbols menu while i am inside the editing dimensions area, but I create an annotation, with the GD&T symbol I need in, then copy and paste in the dimension display. . So I can use this as a work around. Thanks
Sorry, when you're in the what exactly?  In general, a text editing area in which you type and it becomes part of what is shown as part of a dimension/note text ought to support the symbol palette.  Could you describe where you are typing such text and don't have access to the palette?
ron
