Shrink-wrap
  • December 7, 2018
  • 2 replies
  • 1870 views
I have a bunch of models I need to shrink-wrap. These models are large and take hours to complete. In the past I remember having a non visual script I could run and pass commands to do certain things in Creo.
So basically I would run non visual script for Creo, have it open a file, run save as shrink-wrap, accept all defaults. Sounds easy enough! Ideas?
Best answer by dnordin
I believe you are referring to Distributed Batch. It is an install option. Look for the file <loadpoint>/parametric/bin/ptcdbatch.bat. You can do batch conversions with the tool.
Dan N.
dnordin16-PearlAnswer
Dan N.
if you are able to create program in Basic language, then you can generate trail file and run it from Creo.
