Summary: locating hidden solid & surface bodies in Pro-E (similar to SolidWorks)
  • August 10, 2011
  • 0 replies
  • 379 views
I appreciate all the replies (see below). The short answer is to use the
Pre-Wildfire color scheme or the find command.
I forgot to mention, that SW also allows trimming more than two surfaces at
one time (example: 3, 4, etc.). If you use the mutual trim option, you can
trim 3 surfaces and have only one surface body after completing the feature.
Also, I frequently use construction surfaces in SW than use the "delete
body" command to remove the construction surface for good housekeeping
practices. I am curious if any of these direct editing features (SolidWorks:
"delete body", "delete face", "move body", etc) are present in Pro-E WF 5.0
or CREO?
Chris Thompson
