Suppress a pattern via Pro/Program
Hello.
i have a pattern of simple holes that are defined as a dimension pattern, where the number of instances is defined by a Parameter.
on top of that holes (after them in the tree) i have a reference-based pattern of cosmetic threads (nr. of instances is the same as nr. of holes).
i would like to suppress/ unsuppress the entire cosm. thread pattern based on a condition (parameter) based on the pro-program (or something else, like relations, if that's available).
i've tried adding "SUPPRESSED" to the add feature <pattern>, but that only suppressed the top pattern (all the threads still remained unsuppressed after rebuild).
i've also tried to add "SUPPRESSED" to the first instance of the cosmetic thread definition, but that only produced a long error screen that the parent feat is suppressed).
any ideas how could i do that? the problem is that # of instances is often changed, so i can't simple add an if to every instance of it.
here is the definition of the pattern and first thread
ADD FEATURE (initial number 88)
INTERNAL FEATURE ID 27018
PARENTS = 13890(#55)
NO. ELEMENT NAME INFO STATUS
1 Type Reference Defined
LEADER OF A (32 X 1) REF GENERAL PATTERN
MAIN PATTERN DIMENSIONS:
d322 = 20 General_Dims
d323 = 13.5 General_DimsM
END ADD
ADD FEATURE (initial number 89)
INTERNAL FEATURE ID 26335
PARENTS = 200(#8) 13796(#56)
COSMETIC: Thread
1 Thread Surf Defined
2 Start Surf Defined
3 Direction Defined
4 Depth Blind, depth = 20 Defined
5 Major Diam Value = 13.5000 Defined
6 Note Params Defined
MEMBER (1, 1) IN A (32 X 1) REF GENERAL PATTERN
END ADD
(other members of the pattern here)
etc.....
I would like to suppress or unsuppress an entire pattern only, not only specific instances.
if it's suppressed i would like it in the tree anyway (so that it doesn't dissappear).
any ideas?
this is wildfire 3, no idea which M version, but one of the latest.
