Sweep, merge
  • May 25, 2015
  • 6 replies
  • 2261 views
Is it possible to merge a Sweep feature at the same time that you are using the multiple trajectories option?
Best answer by TomD.inPDX
Sweeping a solid into a solid automatically merges the two bodies.  What sweep doesn't have is an "up until" option.
Two ways to tackle this; 1) put the hole in the tube later or do it twice, 2) work with surfaces in your sweep and trim them prior to solidifying them.
adding to the tackle list.
Or, you might be able to reorder the features in the model tree.
Or, you can remove the inside pieces with Remove if you have Flexible Modeling.
Why are my replies disappearing?
Patriot_1776
Sorry, did you say something??
