symbol dimension
  • November 6, 2014
  • 12 replies
  • 3633 views
i cannot modify the symbol of dimension as shown in the image attached. with Creo 2.0
can you help me??
Best answer by Dale_Rosema
Finish making the extrude/revolve feature.
The right click on the feature in the tree and select "edit" (not edit definition).
The dimensions will show up. (You can switch to the names if you like).
The select the dimension you want and the right click and go to properties.
Edit in the "Name" box.
For mine it is d3.
Thanks, Dale
Dale_Rosema
Christian - No image attached.
Thanks, Dale
cspinelli14-AlexandriteAuthor
Now?
not yet,
