thru hole without the word THRU in the callout
  • August 23, 2016
  • 3 replies
  • 1914 views
Can I get a callout for a thru hole without the word "THRU" without erasing the word manually?
Best answer by dnordin
If you're referring to standard (spec driven, UNC, UNF, ISO) hole callouts, you can customize the note callout via the .hol files.
See http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/part_modeling/part_nine_sub/Formatting_Thread_Note… for help on editing the .hol files to customize the note callouts based on hole feature options.
Dan N.
Check your settings because I created a new part, added some holes, created a drawing  and when annotated, only got the diameter symbol and the diameter value.
Creo 2 m220
dnordin16-PearlAnswer
Dan N.
flaporte1-VisitorAuthor
Thank you Daniel, it was precisely what I needed!
